92 RS Collision Light
Old Sep 14, 2010 | 11:57 AM
jignant's Avatar
Default 92 RS Collision Light
I have a 1992 RS low mileage Camaro. I just noticed that the collision light was out so I replaced the bulb. No help. Is there a dedicated fuse for this light and if not, how do I go abou troubleshooting the problem? Thanks!!!
Old Sep 14, 2010 | 12:20 PM
I give up, what is a collision light?
Old Sep 14, 2010 | 12:22 PM
jignant's Avatar
Center brake light in it's own housing inside on the rear glass. If that is not what they are called, my bad...
Old Sep 14, 2010 | 01:05 PM
They call it a third brake light, and avoiding rear end collisions is it's purpose. But cellphones, battery powered razors, and nail polish have pretty much made taillights invisible to the average moron behind you anyway.
Have you checked for power in the socket, with a meter? If it's dead, you may have a pinched/broken wire and would need to go on a fishing expedition.
Old Sep 14, 2010 | 01:46 PM
jignant's Avatar
That's what I was afraid of...
Have not checked with a meter (I assume a standard volt meter) and will have to get some instruction on where to set the meter and place the leads. Car electronics is not my forte', keeping them clean and driving them is. Thanks for your response.
Old Sep 14, 2010 | 08:02 PM
microkid's Avatar
March 2011 ROTM
Technical User
check where the wiring goes into the hatch at the top near the hinge. that seems to be a common area for the wires to corrode or break because of the constant movement
Old Sep 15, 2010 | 09:46 AM
jignant's Avatar
Thanks MicroKid. That gives me a good place to start.
Socom
Nov 9, 2013 01:41 PM
Rent
Apr 22, 2013 11:08 PM
hpd218
Aug 24, 2010 12:05 PM
JGRAHAM
Jul 27, 2009 10:48 AM
evilbeef54
Jul 27, 2008 09:47 PM
