92 maro has a loud pop when turns hard??????
Old Oct 12, 2008 | 03:36 PM
grouch77's Avatar
Default 92 maro has a loud pop when turns hard??????
hey i got a 92 maro rs all sway bar links are new pitman arm idler all 4 tie rods new 1 strut on the drivers side new cant figure it out it pops when u take off with the wheel cut hard i am clueless the strut tower bushing looks ok but looks are deceiveing! if u got any ideas the would be great! thanks
Old Oct 13, 2008 | 06:47 AM
blackz87's Avatar
Default RE: 92 maro has a loud pop when turns hard??????
Try checking the tranny mount....
Old Oct 13, 2008 | 03:18 PM
MadMikeZ28's Avatar
Sounds like you did everything but ball joints. Might want to do those.
Old Oct 13, 2008 | 08:44 PM
grouch77's Avatar
ball joints are a ok if the ball joint was poping like that the front would have droped ive hasd a ball jpoint go and this isnt it. the noise is in the drivers side front end its sounds like its goin resinating throungs the subframe when it does this the sway bar links are new both sides tharuled out strut on drivers but the top of the strut tower isnt new 4 tie rods drag link pitman idler ball joints cant be i can only think its the top part of the strut where the nut is but i can tell if its anygood it visualy looks fine any ideas its not a cheap part its 90 a pce and i would like to make sure if that is the prob before i spend money i dont need to thanks
Old Oct 13, 2008 | 08:46 PM
grouch77's Avatar
its not trans mount that noise would be a thump in the floor i had that prob replaced mount and was fixed its in the front end??
Old Oct 13, 2008 | 09:33 PM
age84's Avatar
March '09 ROTM
it could be the steering boxthat is mounted to the frame. do you have any play it the steering wheel?
Old Oct 16, 2008 | 09:50 PM
grouch77's Avatar
i will check that out that kinda makes sense but iw ill ket u know if it is thanks!
DarkFox
Dec 21, 2011 05:10 PM
Tommyboyink
Oct 20, 2011 12:11 PM
CNCman
Nov 9, 2009 06:44 AM
spamuel
Sep 20, 2009 10:46 AM
69camaro1
Oct 11, 2006 11:04 PM
