92 camaro stalling
HI I new to the board and this is my first camaro I have a 92 camaro rs 305 tbi idels ruff and dies at a stop acts like flooding boggs down when give it gas
i have replaced the air filter and pcv valve same prob but the car runs fine if you take off the air cleaner put it back on and prob comes back anyone know what could be wrong
I Have Gotten Away From ECU's But, Your Problem Sounds Like Fuel Mixture. If Thats The Case It's More Than Likely Sensor Failure. Most Auto Parts Stores Can Plug In To Your ECU And Tell You What Sensor Is Bad. Wish I Could Help You More. Sick
I think I have I the prob down to the map sensor it will idol fine and no stall with the map unpluged a soon as you plug it up stalls or the injectors go to full spray and it fluds out
is there a way to test the map so i dont blow 50 bucks
i wiped the codes thinking it would give a code and not frome me jacking with connections but still no code untill i unpluged the map sensor but could not keep it running untill i did
RFxCamaro
04-04-2010 08:23 AM
