91 rs not running
Old Jun 19, 2006 | 03:01 PM
jbmillenium@hotmail.'s Avatar
Default 91 rs not running
Hi everyone, I just recently bought a 91 rs with a 305 and a few days ago it stoped running, the engine wants to start, but seems like its not getting any fuel, it will run off starting fluid for about 2 seconds then die, if anyone can help me i would really be gratefull.
Old Jun 19, 2006 | 03:40 PM
SickSickSick's Avatar
Default RE: 91 rs not running
have you checked the fuel filter? it's located on the drivers side in front of the rear wheel. can you hear the fuel pump prime when you turn the key on? check your filter first. then if you can hear the pump prime you need to check the pressure. if you can't hear it prime you need to check the relays. if that doesn't help your gonna have to drop the tank and change the pump. you have to jack the body not the axle very high, til the rear wheels just leave the ground. remove the rear axle support and the exhaust. then it will slide out. have anymore questions just hollar. sick
Old Jun 19, 2006 | 04:15 PM
yes you can hear it prime, where are the relays located
Old Jun 19, 2006 | 08:51 PM
On the the 305 models i believe they are toward the center of the firewall . there will be two or three relays there together. i believe the fuel relay has a pink, gray, and a couple other wires going to it. quite frankly tho, if it primed it isn't the relay. did you check your filter?
Old Jun 20, 2006 | 03:16 AM
coolcat's Avatar
sick is more than likely right, when i first got my camaro it would do the exact same thing ( i would crank the engineand then spray some of the starter fluid and the engine would turn on for 2 seconds), try also checking your lines for anything that may be clogging the lines. maybe your fuel pump is on the verge of making its last pump
Old Jun 21, 2006 | 08:15 AM
ill check the filter tomorrow, also i dont know if this will help narrow it down or not, but before this happend the oil pressure was kind of low, and there was a sound coming from the drivers side firewall somewhere that sounded like arching, like a loud tick, that got louder and faster before it died. it was not an exaust tick though, sounded electrical
chevyguyjay
May 13, 2010 09:33 PM
Foxracing254
Oct 1, 2009 11:32 PM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
jake z28
Dec 1, 2008 05:36 PM
1badroc
Jan 24, 2005 02:55 PM
