91 Camaro runs great but it wont go pass 75
Old 04-19-2010, 11:47 PM
did u check in the trany to see if the gears are on the shaft to turn the sensor, they are plastic and can go to pieces over time. should first make sure the signal is being sent to the speedo. all u got to do is pull the sensor out and u can see the gears. im sure theres a way to check the sensor to make sure its working. come on 69 u must have a secret way? lol
  #72
Old 04-20-2010, 12:11 AM
But if I told, it would no longer be a secret.
Since a new VSS costs over $100, it sure would be nice to know if that is in fact the problem with the speedo.
Give this a look see: VSS Diagnostic
  #73
Old 04-20-2010, 06:08 PM
1991chevycamaro350's Avatar
well I had one of the mechanics look and put a computer on it today, he said it idles high (1000 RPMs) so he checked for vaccum leaks and said its my EGR valve he also said thats why its sluggish i told him i can bark the tires,and some times get loose he said that should help you with that problem ,,he showed me that it wasnt holding a Vaccum ,,and he said something about "TPS",,, so i guess my question is should i fix EGR valve first "money is limited"
Speedo $100.00
EGR valve $56.99
TPS 32.99
VSS 110.00
what should i do 69
  #74
Old 04-20-2010, 06:31 PM
Speedo: hold off on the actual speedo itself.
EGR valve: Does your car get emissions tested? If not, removing the EGR valve will cost a lot less. Make or buy a block off plate.
TPS (throttle position sensor), see what the EGR changes first.
VSS: look at the link I gave you and test it.
  #75
Old 04-20-2010, 09:11 PM
im not good at fab work do you know where i could get one i am gonna look around till i get a response
  #76
Old 04-20-2010, 09:37 PM
I can't see the shape of your EGR flange in your pics. Does this one look like yours? EGR Block Off
  #77
Old 04-20-2010, 09:49 PM
by golly i think thats it lmao why would i block it?
tell me why it dont matter to have it ?
jus wondering what the difference of having it and not having it
  #78
Old 05-10-2010, 02:07 PM
well I am back just to say I have the same problem and I am now going thru it looking better than I was but what I have found is a bad egr valve throttle body was double gasket fixed the hesitation problem ,blocking the egr valve sometime this week I have to get the right block plate ,, tranny is shifting to soon so I wanna check vss ,I also seen a sensor in my tranny right after it meets up with the engine it's round with one bolt holding it in what sensor would u say it is I also put spark plugs in it and wow the power I got out of that and and the tb gasket
  #79
Old 05-10-2010, 03:02 PM
the round plug is so the computer can tell the trany when to apply pressure to the clutch. tv cable may need adjusting.
http://www.tciauto.com/Products/Inst...ble_adjust.htm
  #80
Old 05-10-2010, 06:50 PM
what is it that sensor called do you know
Quick Reply: 91 Camaro runs great but it wont go pass 75
