91 Camaro runs great but it wont go pass 75
Old 05-24-2010, 10:15 AM
1991chevycamaro350's Avatar
is that a stock rear end or have my gears been played with
  #92
Old 05-25-2010, 11:03 PM
Hey 69 i went back through my post and seen what you put
Ok, another thought. You have an RS, which originally had TBI. Do you still have a TBI setup? Or what type of FI do you have? If the same TBI unit from the 305 was used on the 350, it's not big enough.
__________________
what did you mean by its not big enough can u get bigger and better tbi units ?if so where would i look ?
  #93
Old 05-25-2010, 11:49 PM
Look on ebay, TBI units and separate injectors are out there. You can replace the whole unit, or just the injector pods, which would be easier.
The 305 injectors are GM part # 5235279 rated at 40 lb./hr.
The 350 injectors are GM part # 5235206 rated at 55 lb./hr.
Here's a little reading info. http://chevythunder.com/gm_throttle_...ction_pg_1.htm
Do some Google searching too, for more details on the TBI and also how to adjust the fuel pressure regulator (it's built into the unit).
You're probably going to want to boost yours some if you replace just the injector pods.
  #94
Old 06-10-2010, 01:18 AM
well i am going to go get a instrument cluster that came out of a car with 222k+ miles on it and its works fine or i can send it back for a full refund !i hope this changes everything for me
SilverRunBootlegger
03-09-2014 07:43 PM
rmh2394
11-09-2011 06:15 PM
MillerOnTheRadio
12-30-2010 11:59 AM
vilidan
11-03-2009 02:18 PM
zoideraserb
01-01-2008 05:35 PM
Quick Reply: 91 Camaro runs great but it wont go pass 75
