'91 Camaro doesn't stay running
Old Aug 10, 2013 | 06:46 AM
CamaroGuy2's Avatar
Default '91 Camaro doesn't stay running
My 91 camaro fires up runs for a few seconds but then it dies out. I can't figure out what's wrong... it gets gas. I changes the IAC valve but that didn't fix it. Please give me some ideas.
Old Aug 10, 2013 | 08:06 AM
It might be getting gas initially, but the pump could be going bad and can't keep up with demand. Or the filter could be badly clogged.
Could be a bad ignition switch, but then it should kill as soon as you back off with the key. To test that, don't let off the key once the engine starts (no, you won't hurt the starter). "Start" and "run" are two different contact positions on the ignition switch. If the engine still kills, you know it's not that.
Is your engine a V6 or V8?
Old Aug 10, 2013 | 07:48 PM
CamaroGuy2's Avatar
its a 5.0L V8
Old Nov 26, 2013 | 10:35 AM
TipTricky's Avatar
Ignition control module maby or could be your timing is off. Can you make the car keep running by feathering the throttle?
Old Dec 4, 2013 | 12:09 AM
martynjoey's Avatar
Thanks for sharing information.
street lethal Z/28
May 23, 2014 11:33 AM
Redcamaro1997
Jun 22, 2012 10:12 PM
mbnntt7
Jul 18, 2011 04:41 AM
Bankos66
LS Series Tech
Aug 25, 2010 11:16 AM
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
