90 RS 305 5.0L Auto
Old Nov 13, 2013 | 02:19 PM
B_Dubya's Avatar
Default 90 RS 305 5.0L Auto
Woke up this morning and tried to start my car so I could drive to work, car wouldn't turn over. It would turn and was making this loud clicking noise. I've heard this type of noise before, it was when my other car's battery was low. I wonder if that's the problem.. maybe I should charge it and see...
When I looked at the battery gauge, it seemed at normal level.
Anyone have any suggestions?
Also, last night there was this ticking noise really close to my throttle body, i'm not sure what that is.
The last thing I did to my car, I did last night, was put some belt dressing on the serpentine belt.
Old Nov 13, 2013 | 03:56 PM
RonnieJ86's Avatar
Jump the battery that should start the car as for the ticking I dunno
Old Nov 13, 2013 | 05:35 PM
B_Dubya's Avatar
should I jump it or just let it trickle charge? I was thinking taking the battery out and letting it trickle charge, sucks because now i'm either gonna have to find the power leak or get a battery disconnect switch.
Yeah its some sort of ticking sound, like hard ticking behind or near the throttle body,
When it's in idle is when I hear it, or in gear. don't really hear it going down the highway cuz u cant hear much with those tail pipes >_>
Old Nov 13, 2013 | 06:14 PM
RonnieJ86's Avatar
if you did a jump then the car can charge the battery it self after a drive around. if you didnt wanna wait for the trickle charge.
Old Nov 13, 2013 | 06:26 PM
RonnieJ86's Avatar
and does this ticking always stay or does it go away after its warmed up?
Old Nov 13, 2013 | 06:34 PM
RonnieJ86's Avatar
ticking noise. - Third Generation F-Body Message Boards Ticking noise from under plenum - Third Generation F-Body Message Boards 1986 305 Camaro Ticking noise - engine - Third Generation F-Body Message Boards heres a few links that could help you check a few things on what could be the cause of the ticking, maybe one of these will fix your problem
Old Nov 13, 2013 | 07:07 PM
B_Dubya's Avatar
THANKS A Lot for the links! wow great help! Umm it comes and goes actually. ill check your links out for a solution. damn I also need to make the Thread title more informational.
Old Nov 14, 2013 | 03:39 PM
B_Dubya's Avatar
So last night I let it trickle charge at 5 amps for 2 hours and then unplugged it and went to bed. Woke up put on the trickle charge for 2 hours. put it in the car,
battery meter read "half"
took it out, plugged it in and set it on fast charge 10amps for an hour.
Put it back in the car, turned key, it read "half" it clicked for a moment and then stopped.
tried to turn the key again, nothing this time. So I called my friend who is head mechanic at Waste Management and he said it's probably a bad connection on the starter. he said the nut is probably loose. So I guess ill check that when I can..
Old Nov 14, 2013 | 04:15 PM
RonnieJ86's Avatar
or could be the battery is bad if its not holding a charge anymore. would you have another one you can put in to test it and see?
Old Nov 14, 2013 | 05:32 PM
B_Dubya's Avatar
I actually do have another battery! same type, fortunately the cavalier and Camaro use the same one. I wil ltry it as well.
