90 Camaro Driver Door Bushings?
I was wondering if it is better to remove the door to put in the new bushings and rod. i removed the old one by moving the door spring, but i can't get the spring back straight. I can't get the new one to fit in right. Also, is there 2 busings or just one. I only saw one but the kit came with 2 sizes.Only one size fits though.
Thanks
Error_505
Thanks
Error_505
RE: 90 Camaro Driver Door Bushings?
well you should always take the door off when dealing with the hinges. I cant answer the second one. I am pretty sure that there is only one bushing for each door. but I could be wrong just take the door off and find out
