89 RS turbo
89 RS turbo
ok i have an 1989 RS camaro
it has a 2.8L
i just picked up a turbo off a friend for $250 cuz hes parting out his supra.
and what else do i need to make it work for the 2.8l iv never worked with turbo. will it even work i cant find anything on the net.
it has a 2.8L
If you havent actually paid him the money yet, I would give him the turbo back. If your going to turbo it. Buy a whole complete kit. The bearings in turbos wear out and the fin in the middle wobbles around. I would want a NEW turbo along with everthing to go with it. It would be cheaper just to buy you a v8 camaro and you would have more power than a turboed v6.
turbo only needs rebuilt if it needs them. if properly driven and idled down before shut down, a turbo can last a million miles. however, you may want to look into swapping the engine. the 2.8's bottom end is not too reliable with power adders. you can look into getting a 3.8 and build that similar to a GNX.
LOL, Sorry but turbo a 2.8? Many of those things didn't make it out of warranty without needing a crank. Why not just pull the pan and hit the crank with a big sledge hammer. It will be a lot cheaper and have about the same results.
That would also be why no one makes a kit for it. Step one would be upgrade the crank and rods.
Sixty7 Camaro
04-11-2009 12:54 PM
