89 iroc dies after starting
RE: 89 iroc dies after starting
i dont know if this helps but on my aussie v8 304 simalar to a chev mine was doing this and i found it was a lose wire in the throttle postion sensor running in the loom, if you shook my loom the idle would go everywhere and would run liek crap, recrimp and shes fine. maybe ur has the same principal
ORIGINAL: nj85z28
how is the cat? i had an 85 that did something similar and the cat was original and clogged. also, do a major tuneup if you havent lately
MSCOT77: Is this only on a cold engine? What grade gas are you using? I have an 89 with a 5.7 and this also happens to me occasionally on a cold start (over night ) I am using 89 OCT right now. Same situation though, when I get rollin, I keep rollin. No rough idel or anything else (fingers crossed now that I jinxed myself)
Brendan Barber
08-23-2012 08:03 PM
iroc895.7tpi
82-92 V8 Tech
10-24-2010 08:38 PM
