87 iroc-z overheating
Old 05-13-2010, 08:22 PM
ScottD's Avatar
No, overflow would dribble down in front of the pass front tire area. But if you cant find a leak, and you arent regularly loosing fluid, I wouldnt worry about a leak. So we have identified ONE issue...the missing Air dam. That part is AS important on highway speeds as your cooling fan. Please dont think that part is cosmetic or just 'helps a little'....its a MAJOR part of your cooling system at highway speeds. Dont even respond to this post until you replace that part. (OK, Im kidding about not responding but Im trying to drive the point home.....)
Old 05-14-2010, 08:08 AM
djs383's Avatar
Have you checked to make sure it isn't from the heater core?
Old 05-14-2010, 10:05 AM
IROCK11s's Avatar
ok, i took out my thermostat and is now running w.o it, i replaced the fan with another slim electric fan hooked it up to a fuse that comes on with the key, so shes keeping cool, i have the air dam but the previous owner, seems to have lost the bolts to it, so i cant install it
Old 05-16-2010, 12:02 AM
IROCK11s's Avatar
STILL OVERHEATING! i put in a brand new electric fan, put the air dam on, did a coolant flush. AND SHES STILL HEATING TO 250 DEGREES + !!! any suggestions?
Old 05-16-2010, 09:47 AM
ScottD's Avatar
Well, you probably shouldnt replace the radiator. Seeing how you have replaced everything else, why would you want to go and do that????
Are you running an aftermarket sensor, where is it placed, have you adjusted your timing lately?
Old 05-16-2010, 11:52 AM
IROCK11s's Avatar
The radiator is only a year old its in almost new condition that's y I haven't replaced it. It seems to be just a factory radiator. And it seems to work fine. She runs alright on the highway at around 230 degrees just a little hot but at redlights or city driving it just over heats
bryan0609
82-92 V8 Tech
32
05-07-2012 06:57 PM
ssteve12121
03-22-2006 11:10 PM
Quick Reply: 87 iroc-z overheating
