87 camaro 2.8 needing a 350
Old May 8, 2008 | 05:15 AM
camarozombie's Avatar
Default 87 camaro 2.8 needing a 350
ok hello im new to this so im just going to list my ???'s
if i want to put a 350 in my 87 with a 2.8 do i need or will it work?
1.trany crossmember?
2. engine mounts?
3. if the trany crossmember isnt the same will one out of a camaro with a v8 bolt in the same spot?
is there a swap kit avaliable? please help.........
thank you
you can reply on here or e mail me at zombiehate666@hotmail.com
thanks again
zombie
[IMG]local://upfiles/13143/01B14735E5FE4F3DB6BEF73E5C8020E4.jpg[/IMG]
Old May 8, 2008 | 02:29 PM
irocktheIROC's Avatar
Default RE: 87 camaro 2.8 needing a 350
ill sell you my 350 and my iroc-z...it has a 305 and a 700r4, so you can swap your engine and **** and put a 350 tpi in it! haha
Old May 8, 2008 | 02:35 PM
dude im a poor bastered i wish i could buy that! i would be all about it lol can you aswer any of my ?'s tho?
Old May 9, 2008 | 12:50 AM
you will need pretty much everything, engine, trans for v8 (has GOT to be from a v8 car) probably a driveshaft, the crossmember should be ok, you need the engine mounts for sure, the rest of the junk should work, maybe look into a radiator from a v8 car or something...
John@SurfCityCorvettes
Oct 10, 2014 07:51 AM
!WildChild!
Oct 17, 2011 08:22 PM
marvelboy_04
Oct 20, 2009 10:39 PM
Crayola
May 17, 2009 10:52 AM
