84 camaro
Old Jan 18, 2007 | 04:14 PM
cagle07's Avatar
Default 84 camaro
I really need some help. I have a 1984 berlinetta camaro. I have had to replace my transmission and my flywheel. After i replaced them i havent been able to get my car started. So then i by passed my ecu and still got nothing. then i replaced my distrubuter cap and my rotor. I also replaced my coil on top of the distrubter and still. I had my starter tested and it was fine. And i still have not been able to get my car started back up if ne one could help me i would really appreciate it cause this is my only vehicle and my parent wont by me a new one. So if u come up with ne thing please email me at kellycagle07@hotmail.com. Thank u
Old Jan 18, 2007 | 05:11 PM
MadMikeZ28's Avatar
Default RE: 84 camaro
If it ran before you did the trans then you did something to it. Go over carfuly what you did and anything near where you worked on it.
Old Jan 18, 2007 | 05:33 PM
cagle07's Avatar
i put the tranny in over 6 months ago the flywheel just broke recently and thats when i started replacing everything.
Old Jan 18, 2007 | 09:46 PM
MadMikeZ28's Avatar
ORIGINAL: cagle07
I was going on this information you posted. Have you checked for spark? Is there voltage to the distributer? Do you have a carb? Can you see fuel squirt when you push the throttle?
Old Jan 19, 2007 | 05:37 PM
cagle07's Avatar
its getting fire and its getting gas but im not exactly sure what u mean by getting voltage.explain.
Old Jan 19, 2007 | 08:06 PM
MadMikeZ28's Avatar
If its getting spark then its getting voltage to the coil so dont worry about that. You have just about all you need for it to run. Did you happen to unplug any wires? The ones to the module in the distributer? Maybe they got pinched and cut. The tan wire that needs to be unpluged to set the timing?
Old Jan 20, 2007 | 10:41 PM
cagle07's Avatar
everything is plugged in no wires cut. do u think it could be my ignition module?
Old Jan 21, 2007 | 12:28 AM
MadMikeZ28's Avatar
There is that possibility. I think Autozone can test the modules.
Old Jan 21, 2007 | 12:58 AM
cagle07's Avatar
You have to take off the distrubuter to get to that right or something like that im not really sure bout that.
Old Jan 21, 2007 | 01:02 AM
cagle07's Avatar
also when we checked to see if the car was getting fire we took one of the spark plug wires off the engine and stuck and wire in it and stuck the end of it to a screw it arched but the arch wasnt blue it was yellowish color and usually when u get a good arch i no that it is usually blue.
