700R-4 Lockup Conversion Kit
Found Some Info, Thought I Would Share. For Those Wishing To Use A 700R-4 On A Non-Computer Application, You Can Buy A Vacuum Conversion Kit For $179.00. As Opposed To Having To Alter The Cross Member It Seems The Better Way To Go. Sick
Actually I Was Mistaken. The Kit Works Off A Pressure Switch And A Solenoid. You Can Order Them From Autozone. It's Made By Painless Performance. The Part Number Is #60109
