4barrel carb intake??? HELP!
Well im pretty new to all this demestic stuff as you guys can tell from my earlyer post haha but
Can a 4barrel carb fit on a a normal intake? like an Edelbrock Performer RPM?
RE: 4barrel carb intake??? HELP!
it depends, the intake manifolds are different. that one prolly will fit. ifthe hole is about4inches in a square and a bolt configuration almost resembling an X it should fit. most aftermarket intakes are for 4 bbl. they also sell adapter kits from 2bbl to 4 and vise versa. but there might be a hood clearance issue though.
I have the Edelbrock RPM Performer Intake on my 350 with a 4 barrel 750 Holley carb. Hood clearance will be effected by the spacers and what type of air cleaner you inted to use
ORIGINAL: age84
