350 turns out to be sb 400
Old 09-19-2009 | 09:49 AM
spamuel's Avatar
Default 350 turns out to be sb 400
Hey Camaro Enthusiasts
I'm Sam and I've just bought my first camaro. It's an '87 with a blown carburated 305 and has all emissions controls stripped out. It also has a 5-speed manual tranny . Since it's carburated which gen do I belong in?
Since the engine doesn't work and because it's a putzy 305 I decided to buy a rebuilt 350. When I got the engine home and checked the stock numbers I learned that it's actually a small block 400. This could be good or bad what do you think? I've heard that I'll pay a ton for the flywheel that I need ):
Old 09-19-2009 | 09:59 AM
microkid's Avatar
March 2011 ROTM
Technical User
you are in the correct generation, third gen is 82-92. sounds like you got a good deal on the sbc 400. as far as a flywheel, it may be a bit hard to find. i think the 400 uses a blanced flywheel, but i may be mistaken. a scrap yard would be a good place to find one.
Old 09-19-2009 | 11:00 AM
Y2K's Avatar
Y2K
The 400 is externally balanced so it will have to be a flywheel from a 400 exclusively.
Old 09-19-2009 | 02:31 PM
...And a harmonic balancer for a 400, if it doesn't already have one.
Hmmm..let's see. 400 cubic inches, or 350? I'll take 400 to win Alex!
Old 09-19-2009 | 06:20 PM
ScottD's Avatar
A blown 305? Now thats an exercise in futility........If you dont want that 400 Id gladly take it off your hands!
Old 09-19-2009 | 11:02 PM
microkid's Avatar
March 2011 ROTM
Technical User
im thinking he means blown as in dead and not as in supercharged?
Old 09-20-2009 | 09:21 AM
spamuel's Avatar
Thanks for your guy's help, I figured out my solution. Summit sells weights to bolt onto a flywheel to balance the 400 (:
Old 09-20-2009 | 10:46 AM
ScottD's Avatar
Yeah, that would make more sense, wouldnt it...........
craby
07-18-2012 10:43 AM
Jerry95lt1
03-29-2011 12:24 PM
Jerry95lt1
10-28-2010 01:38 AM
CNCman
11-09-2009 06:44 AM
jaimejames2
04-18-2007 01:38 PM
Quick Reply: 350 turns out to be sb 400
