335 stroker
well i thought about building a 350 for my iroc but i decided too many of those around.. so i think im gonna stroke out my 305 to a 335... anyone have any input on this... is it worth my time? also where can i find a good kit for the 335? i mostly just wanna show people that a powerful engine can be built out of a 305..if the stroker doesnt get me where i want to be theres always nitrous..
Currently building 305 as well. The L69. I don't plan on stroking it though. Already has pistons and crank from 350, we'll leave it at that. Any input from people on ideas, kits or parts though would be helpull. I plan on buying the same type of cam in the 300 hp 305 article but the heads I'm unsure about and my carb is only a 650CC.
do a search or check www.thirdgen.orgi think their are a couple of guys on that site that have done a 335 stroker and can probably point you in the right direction
Building a 72 pacer with a 304 is being different. Picking an engine platform that will limit you in the future will be something you will regret.Your going to put all that money in a short block thatshould not see 300 hp. In thelate 80's early 90' I replaced/rebuilt a lot of the 305 TPI iroc's under GM warranty. I can not remember changing one 350 in a camaro. I didrepair a few vets 350's but I do not remember any crate motors or bottom end damage.
I am not saying its a bad engine as designed its just those 250 Hp cars where closer to the limit of what the 305 could handle. I did just as many 2.8/3.1 and even more 2.5 head gaskets at the time. Oh and dont get me startedon those dam2.8 rear mains in the S-10's.
I think the 85's where the worse. GM used to pay 6.5 hours to remove the engine pull the pan, replace the seals get it all back together and test drive it. I got paided 6.5 hours for 10 hour days a few times.
