305 heads on LT1?
they will fit, but you would only be able to run them for a very short period of time before your motor blows (or have to clean the carbon off of your pistons, valves etc. i heard lots of dirt car racer use them on 350's for like a weekend to get more compression. might not be able to use straight pump gas either depending on your compression ratio.
Just to be clear we're talking early LT1 from the 1970's correct? not a '90's LT1.
What will be the best heads kinda depends on what you have for internals and bolt on's,IE pistons, compression ratio,cam specs, rotating assembly rpm range,intake manifold and carb,etc.
The LT1 motors were 4 bolt main steel cranks with high compression pistons and a bum-pity bump solid lifter cam as well as an aluminum high rise intake and Holley carb.
The stock heads had the 2.02" intake valves so if you are planning on a similar build you'll want to go with a set of 2.02's like the stock LT1 heads or something better like Trick Flow or Edlebrock aluminum heads.
A milder build and you could use a set of 1.94's off a more standard 4 barrel carb'd 350 but you don't want a set of 305 heads of any kind.
if its just a stock lt1 maybe find a set of 64cc vortec heads or set of cammel humps 1.94/1.5 or 2.02/1.6 valves that should wake it up a bit with a decent cam/lifter set. but i was told to stay away from the 76cc (624, 882 etc.) heads if you want more hp.
Plus he was asking about an LT1. The 70's engine was an LT-1.
soooo,,, is this a lt1 or a lt-1? still dont know. heres something to think on. maybe i have it in the right thread this time.
http://www.camaroz28.com/forums/arch.../t-141362.html
^ Oh man, now my sides splittin open! Nice link, I think I may have read one like that before.
It's so damn good, I even read it twice...the WHOLE thing! lol
kuhlman187
67-69 V8 Tech
02-12-2015 08:14 AM
