305 cam in a 350
Old Oct 28, 2006 | 01:20 AM
ashleyshuggybear's Avatar
Default RE: 305 cam in a 350
i pesonaly think that you should just put a fresh bump stick and lifters in that 350. but dont try doing to much to it being a truck engine from 93 chevy. the compression is still low but you can get away with a 204or 224 degree cam with any where from 420-445 lift. the comlete kits from summit are only like 60-70$ so just replace the lifters and cam.
uncle bill's Avatar
If the 350 cam is in good shape, it would be the best to use.
Old Oct 28, 2006 | 01:27 AM
motor tec's Avatar
k thanks ill reuse the 350 cam... also to to ashleyshuggybear i dont think the compresion is going to be that low.. it was in the low 8 (i think?) but i milled them .20 so my guess would be that it's in the top 8's low 9's now. wont know for sure till i get in runin so i can do a test..
