1992 camaro rs with 305tbi
Old Mar 11, 2014 | 03:47 PM
James Glenn's Avatar
Default 1992 camaro rs with 305tbi
My 92 camaro rs is leaking coolant off the back.of the motor and overheating ,it's like a puddle of coolant ...do anyone have suggestions on what to do....?
Old Mar 11, 2014 | 03:53 PM
Either fix it, or invest in paper towels!
Need to know just where the leak is leaking from. Wipe everything clean & dry, run the engine, and watch for the waterfall.
Old Mar 11, 2014 | 04:22 PM
When it leaks from behind the motor does that usually means intake gasket are loose...or do you have a idea...
Old Mar 11, 2014 | 05:07 PM
Could be intake, but I wouldn't expect it to be dripping in the back unless the leak is on the side and running back. External head gasket leak, possibly. From a core plug is another possibility. Can you trace the leak back to the source? When you say it's leaking off the back of the engine, do you see it up high, or down low?
gbettner
82-92 V8 Tech
13
May 3, 2013 12:03 PM
Badrs2810
82-92 V8 Tech
Sep 16, 2010 07:41 PM
camarojunkie
82-92 V8 Tech
15
Sep 23, 2009 08:27 PM
missmy72ss
May 8, 2008 09:49 PM
KRobbins
Jul 27, 2006 11:21 AM
