1991 Z28 TPI Fuel Pump question
Old Jun 17, 2012 | 01:47 PM
jakobkay60's Avatar
Default 1991 Z28 TPI Fuel Pump question
So I recently purchased a 1992 Camaro z28 non t-top with the L98 TPI engine in it. The only problem is the fuel pump has went out on it. This camaro has aftermarket corvette injectors and Im looking to run about a 150 shot of NOS in the future.So my question is should I go with a factory fuel pump or performance fuel pump. Will the factory fuel pump push enough for the after market injectors or not. Any help is appreciated thanks!
Old Jun 21, 2012 | 07:28 AM
microkid's Avatar
March 2011 ROTM
Technical User
the aftermarket pump would be the way to go if you are planning on nitrous. theres a few 255 lph pumps out there, i chose to use a holley. if it does indeed have aftermarket injectors, you will need to get a custom prom or it will run very rich constantly
pcarollo
Sep 30, 2014 10:08 PM
LesDrive
Apr 30, 2010 09:40 PM
91camaropalmer
Dec 19, 2009 05:03 PM
murderd96z28
Nov 2, 2009 01:26 PM
oneals camaro
82-92 V8 Tech
Mar 31, 2008 01:56 PM
