1988 fuel injected 350-carb question
Old Oct 12, 2009 | 02:15 PM
bigjim's Avatar
"your going to have to drop the gas tank get rid of the electric fuel pump and replace it with about a foot of fuel line"
You do not need to drop the tank or take out the old pump ( disconect the electricle to it) use the return line from the EFI to feed the mech pump and carb. the return line is the same length as the electric intank pump. This will save you a ton of time and aggravation in dropping that tank.
Old Oct 13, 2009 | 11:40 AM
newtocamaros's Avatar
any chance you have a link for that block mounted fuel pump? I am switching because i want one camaro carbed one with efi and one with tpi just because i love camaros. that and my favorite way to make mom and dad mad is tell them that i will have a camaro for each day of the week. (gotta start somewhere after i build my house it will be month then year)
mighty mike's Avatar
the return line doesnt go down far enough into the tank.
Old Oct 13, 2009 | 02:55 PM
That's what I'm saying too. When I was inside my tank, the only one going to the bottom of the tank (what you need) was the pump/supply pickup.
And check the engine block. An FI engine most likely isn't going to have provisions for installing a mechanical fuel pump. Maybe if it's a transition year engine, but otherwise not likely. Then you'll need to keep the electric pump and install a return type fuel pressure regulator before the carb. Unless you want to drop the tank and do a pump bypass.
Old Oct 14, 2009 | 11:36 PM
CamaroKid12001's Avatar
But in the end your gonna be glad that you did a bypass and installed the pump on the side of the block, because if the pump would ever go bad your gonna have to cut your exhaust off (unless they are ran really wide) and drop the tank then re-do your exhaust.
So really its gonna save you TIME and MONEY.
juarch328
Jun 15, 2011 07:18 PM
draggo144
82-92 V8 Tech
40
Feb 22, 2011 09:04 AM
84_transmarobird
82-92 V8 Tech
Nov 5, 2010 04:57 PM
c4maro
Jan 2, 2009 10:36 PM
1983camaro
Oct 25, 2006 02:58 PM
