1988 Camaro V.6 -help.
Old Jul 16, 2010 | 11:13 PM
BRIAN10197's Avatar
Default 1988 Camaro V.6 -help.
Hey guys i have 4 questions.
My camaro saids 52097 miles i know its not that much since its a 88 so i was wondering is their any way to find out how many times it rolled over?
I was wondering.. My dad washes his Underhood of his sequoia very often the dealership said its good for all the stuff under the hood of the car to stay clean all the stuff around the engine and the engine itself.
Well my main question being since thats a 2001 toyota i was wondering if it is safe to clean my underhood engine area and it surroundings with a hose or is it better to use a rag. Was just wondering.
2nd question.
Ive noticed when i drive the camaro i smell gas, and my gas went by fast i know it might be a leak or something but i cant find any gas leaks on the garage.... but can it possibly be that the gas has been sitting their for a year thats why it ran out so fast? Im just trying to find the cause and where i should look.
3rd question.
The camaro is a manual. When i shift 1st and 2nd gears their is a loud screech it sounds like the gears are grinding. But thats only 1st and 2nd gear.. 3rd 4th 5th doesnt make the sound. I was wondering if anyone here had that problem? Ive heard clutches/gearboxes are very expensive to fix
some pics NEWER ones at top
Old Jul 17, 2010 | 01:29 PM
BRIAN10197's Avatar
Bump o.0
Old Jul 19, 2010 | 09:10 PM
BRIAN10197's Avatar
Help?
Old Jul 21, 2010 | 12:16 AM
86CamaroZ28's Avatar
August 2010 ROTM
Hey man, welcome.
Ok,
there is no WAY to know how many times it rolled over, unless the previous owner had documentation??? But you can use logical reasoning, you would no if the car only had 50,000 miles on it cause that would be worth an extra buck, and I dont think the car would have 250, it's probable 150.
Don't spray your underhood! third gens don't have the best electrical system, many times relays and wires can be completely unprotected; I would stick to using a wet rag.
Now I wouldn't think that it has a gas leak cause you would smell it and see it in the driveway... Do you only smell it when it's running? Also gas that was sitting for a year probable should have been drained, gas shouldn't be used only after 2 months of sitting...
Old Jul 21, 2010 | 12:19 AM
August 2010 ROTM
Now the screeching, I could be your clutch slipping; you'll just need to replace it... The lower gears are much more power to the clutch, so that may be why it only slips in 1st gear. Check your transmission oil level, make sure that its good, and it should be a clear pink or light red color, if it's murky change it.
Old Jul 21, 2010 | 11:05 AM
BRIAN10197's Avatar
I only smell gas when it runs do you know how much it would be to replace the clutch?
Old Jul 21, 2010 | 12:25 PM
gfrench's Avatar
clutch can range from $90 to a few hundred.
You said a screech, Ive never heard a clutch screech, are you sure your not barking the tires. Need more details. Clutches slip they dont screech. Pressure plates can clank, u-joints clank, gears whine, tires screech.
As for the fuel, look for a fuel leak when the car is running. Check around the fuel rail. May be leaking onto the intake or exhaust and it would burnup before hitting the foor.
Also, the car may just run rich.
Old Jul 22, 2010 | 12:36 PM
1BADA$$RS's Avatar
when in doubt and need it more stout rip the v6 out, what ever you do DO NOT RUN OCTANE BOOSTER i made that mistake with my first third gen
Old Jul 22, 2010 | 05:04 PM
Valicswarrior's Avatar
i sprayed my motor but i bagged my distributor and covered as many of the electrical componets as i could so i can get the bulk of it clean but like someone else said you need to be careful when doing this.
Old Jul 23, 2010 | 01:53 AM
1BADA$$RS's Avatar
im pulling my motor out in about 2 weeks to paint it and make it all purty along with the engine compartment lol but yeah dont use octane booster itll run like SHYT
rrobin02
Sep 8, 2012 10:58 PM
95boostang
82-92 V8 Tech
12
Feb 7, 2011 02:26 PM
BRIAN10197
Aug 3, 2010 03:45 AM
db
Apr 28, 2008 08:41 AM
