Question about a Spare Tire
Old Sep 22, 2012 | 04:37 PM
Cesko81's Avatar
Default Question about a Spare Tire
Hello i recently bought a 1981 Z28 Camaro for parts, and i guy i bought if from threw on a spare tire to it and it looks to be an original camaro one. But i cannot tell what year it is from it looks similar to a second gen but could also be a third? Can any one help.
Attached Thumbnails Question about a Spare Tire-imag1250.jpg   Question about a Spare Tire-imag1251.jpg
Old Sep 22, 2012 | 06:24 PM
Look closely at the rim near each raised boss between the lug nut holes. You should see a date code.
Old Sep 22, 2012 | 07:27 PM
BasicConcepts's Avatar
Technical User
assuming its the original tire you can check the dot code. heres an example of a code - 06 u44 2 4678. the 4678 is the date code, meaning the tire was made in the 46th week of 1978
Old Sep 22, 2012 | 08:26 PM
Cesko81's Avatar
I do not see a number any where on the rim like that. The only numbers i see are GM 70, 5, NI or IN, and T16 10 12 XA
Old Sep 22, 2012 | 08:29 PM
Technical User
are you talking about the dot code? it will be on the sidewall of the tire
if you look at the 2nd pic you can see the dot code at the 9 oclock position... kinda looks like 0466 to me but its not a great pic and im on a cell phone
Old Sep 22, 2012 | 11:58 PM
That number tells you it's a GM wheel, but I don't recognise the numbers. Might be different for space saver wheels than regular wheels.
daredevil95
Aug 12, 2013 08:31 PM
DrQuincy
Oct 12, 2012 11:29 AM
rachel11
Apr 6, 2012 08:56 AM
Srane
Sep 13, 2010 09:38 PM
Alabama Camaro
Mar 9, 2010 03:36 PM
