Front Parking Light Replacement 1970 z28
Old Aug 6, 2018 | 11:55 PM
greenmachine1's Avatar
Smile Front Parking Light Replacement 1970 z28
Can anyone help me with how I replace the front parking light on my 1970 Z28? I removed the 2 screws that I beleive are holding in the bezel and also pulled the grill off as I could not get my hand to the back of the light. Still can hardly get to the light bulb. There has to be some easier way or trick to replace the light. Thanks
Old Aug 7, 2018 | 12:04 AM
2 screws, sounds like yours is an RS (round lights). Once the front screws that hold the lens to the housing are removed, the lens will/should pull right off. But years of being fastened together can make the lens stick to the gasket. You may need to do a little careful prying, be sure to protect the paint.
Old Aug 7, 2018 | 12:15 AM
Just to mke sure we are talking about same light, it's not the main headlight but the front parking light.
Old Aug 7, 2018 | 07:33 PM
Right. The screws through the front of the lens is what holds the lens in place. Once the lens is off, you can access the bulb.
Ennisdavis23
May 30, 2017 12:01 PM
KJW468
Feb 7, 2013 09:30 AM
Chevy101
Oct 14, 2010 07:56 PM
bashgod
Nov 24, 2009 01:50 PM
trailerparktrash2009
Aug 17, 2006 07:15 AM
