decklid torsion rods
Old Jun 10, 2013 | 02:12 PM
mel1rocky's Avatar
Default decklid torsion rods
hey!, im looking to find someone who has changed the rods in the decklid hinges,
passenger side is very weak, I have a new one just not sure hot to go about changing
any help would be great
Old Jun 16, 2013 | 01:58 PM
Didn't know any 2nd gen Camaros had decklid rods? Or do you mean the torsion springs that go hoizontally to hold the trunk lid open? If you mean the otrsion springs, then you should check to see what notch they're in first, as they can be relocated to a different notch to add more spring tension, and save replacing them.
Old Jun 17, 2013 | 12:19 PM
B.M.'s Avatar
If you find that they do need changed,be careful,they are under high tension.Most people use a bar to take them out of the notch and to put the new one in the notch,and they cover the rear window with cardboard,blankets,and whatever else they can,because if the torsion rod gets away from you,it will swing right toward the rear glass.
Old Jun 18, 2013 | 07:25 AM
mel1rocky's Avatar
Default torsion rods
thanks a lot guys, I was a little concerned as of the back window being there,
the driver side has plenty of tension but passenger side is very weak even after moving to a different notch
im gonna give it try and let you know how it went
Old Jun 18, 2013 | 09:14 AM
Get some Masonite, or plywood, and after removing the cover you can duct tape the board above the rods to protect the window. That way if one slips it wont hit the glass.
YAV8
Aug 15, 2014 11:12 PM
jkeaton
Sep 1, 2012 08:41 PM
AMP3D
Apr 5, 2011 02:38 PM
purpl96
May 9, 2008 10:27 AM
