79 Camaro Berlinetta window loose and wobbles :how do i fix?
I have a 79 Camaro Berlinetta, the previous owners did nottake good care of it and there are many issues wrong but my main concern rightnow is that I’m trying to fix passanger window from wobbling back and forthwhen you touch it, you can move it back and forth with your hand even, andrattles when you close door. I’m thinking I need to take inner panels off doorbut I don’t know what to do after that.
I hoping someone could help me with this because even thoughcar needs lot of work I love it.
Most likely the nylon roller guides have either worn out, or fallen apart. Here's a link to an online copy from the Camaro disassembly instructions for the door glass assembly.
Camaro Restoration Handbook: Ground-up Or Sectional Restoration Tips ... - Tom Currao - Google Books
Thank you so much, I will check out the link asap, because I was actually hoping to try and work on it this sat. But if i need new nylon rollers I might have to wait on that project and start on fixing interior. How long does it take to order new nylon rollers?
Masospaghetti
Mar 14, 2010 09:26 PM
