96 Camaro seats feel loose and flimsy - is this normal??
Old Mar 11, 2010 | 12:44 PM
Masospaghetti's Avatar
Default 96 Camaro seats feel loose and flimsy - is this normal??
Hey all - 1996 Camaro RS, 3.8, 148,000 miles. Both the driver and passenger seats feel weak - they "flop" around when nobody is sitting in them (looseness in the recline mechanism?) and also have some looseness around the seat track. The tracks themselves are bolted down tight. Is this typical? Can I do anything about it?
It makes the car feel cheap and I wonder about the safety of it as well. Any input is much appreciated!
Old Mar 11, 2010 | 06:25 PM
nnewquist's Avatar
In mine, there's a tiny bit of play in the base of the seat, but not much. The rear of the seat can be rotated a few inches forward/backward if nobody's sitting in it, but once you put your weight on it, my seats stay where they're put.
Are your seats powered or standard?
Old Mar 11, 2010 | 06:35 PM
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
My driver's side is a little floppy, but it's not noticeable unless I pull up on the thing to make the top part fold forward, then pull it back. Then it bounces a little. If anything, just take the seats out and check the underside. My seats aren't power and there's only 4 bolts to take out. Something might be loose, broken, or missing.
Old Mar 14, 2010 | 09:12 AM
Standard. I think mine is the same way, it doesn't have play with someone sitting in it. I guess this is normal then?
Old Mar 14, 2010 | 09:26 PM
libertyforall1776's Avatar
In my '02 RS, the driver seat has play when you brake or accelerate sharply or wobble front to back in the seat, the track has a problem. Supposedly the only fix is track replacement, unless anyone knows otherwise?
Roger3
Sep 3, 2012 05:06 PM
Matt Moore
Feb 29, 2012 09:33 PM
hjistc
Dec 7, 2011 01:29 PM
auto
Apr 9, 2010 11:52 AM
sshogun
Jun 10, 2006 09:52 PM
