1981 Stock wheel size and tires
Old 12-16-2015, 02:11 AM
GuitarzMyThing's Avatar
Default 1981 Stock wheel size and tires
Hi!
I just bought my first car in May, a 1981 Standard Camaro and looking to start years of resto on it... I am just doing research on wheel sizes along with the tires that go with it.
Right now it has 14x7 4-1/2 wheels on it... I am looking to maybe get a 15x8 4-1/2 for now with a Mickey Thompson ET Street Radial Tire at 235/60/15 for both front and rear... Will I need to do any body work around the wheel well to accommodate the wheels/tires or will I be fine?
Old 01-20-2016, 03:39 AM
80sz's Avatar
They will fit with no issues
Old 06-14-2017, 07:15 AM
DrPepper1010's Avatar
I have an 81 Z28. All stock suspension.
Right now the front is: 15x7 wheel w/ 235 60 15 tires. The rear is 15x8 wheel w/ 245 60 15 tires. No clearance problems.
I want to go to 17x8 wheels all around w/ 235 60 17 tires. Does anyone know if this combo will work on an 81??
Old 06-14-2017, 03:32 PM
Zspoiler's Avatar
I have a 1979 Z-28 RS Camaro ,When I bought the car it had 15 x 7 Appliance "Turbine " wheels on it.with 235/60R-15 on it and have put a 245/6015 in the rear ,I have run a 16 x 8 and 17 x 8 wheels on it now. With 245/45 17`s front and 275 /40 17 rear on a 17 x 8 wheel with 5 " of back spacing.with no rubbing. So it depends on what backspacing and tire bulge you have,At the very least yo might have modify the outer wheel will lip.because of what tire pressure you go down to.
Attached Thumbnails 1981 Stock wheel size and tires-130044932860518017_26257430996_o-1-.jpg
Old 04-03-2019, 12:54 PM
Larry 79's Avatar
I have a 79 Camaro I installed 17 x 8 wheels all the way around and used a 245 50 17 tire with a four and a half inch backspacing the fronts fit extremely well and look great in the fender well but the back could use a half inch spacer to move the tire out to be in line with the front
Old 04-07-2019, 05:04 AM
ZL1CAMARO's Avatar
Larry awesome car and wheel tire combo looks great lets add that spacer and get more pics. The earliest 2nd gen camaros have same track width as front although from about 71 or 72 on , gm decided a rear brake change and or altered rear end tubes and this causes the rear to be sucked in , making the front wider than the rear. So yes the track width is definitely narrow by a large amount , imight say. also the narrow rear caused the rear tires to wear extremely quickly putting angular constant pressure on them and then the race cars moved to much wider tires as it needed them. i'm changing my camaro quarters to firebird or other quarters and building them out more putting on large brakes and axle tube extensions with truck arm suspension, pan hard, and link lever, also my engine and trans are getting moved back some inches with firewall mods fox body front coil over suspension and manual rack. i'm selling my front clip to fabricate a 69 Shelby like front end still with an internal bumper .
Old 06-22-2020, 06:28 PM
Phil Leroy's Avatar
Default tires
Hi new to this forum I have a stock 1981 Z28 camaro I want to buy new tires what size of tire should i get for the front and rears wider and taller the better that will work without issues thx
Old 01-17-2024, 10:11 PM
cb7501976's Avatar
Default Hi I am trying to figure out what ties will fit under my 76 Camaro with 16-in rims
Trying to find the right size tires
G2camaro
12-20-2019 04:59 PM
Texas70z28
03-11-2012 10:42 PM
ThirdGenCrazy
03-25-2010 07:43 AM
MochaCaliGirl
01-28-2009 09:17 PM
JordonZ28
12-12-2007 11:23 AM
Quick Reply: 1981 Stock wheel size and tires
