Would new heads do?
Old Aug 31, 2017 | 02:55 PM
Trebor65's Avatar
Default Would new heads do?
Hi!
I´m a newbie in the Camaro community, have a 1975 LT, original apart from a Grant steering wheel.
I want to get some more power from the engine, since it´s a "smog" engine.
I would settle for about 50 more horse power, but can I get more power with a different cam, 4 barrel and headers, keeping the original heads ?
Or are the heads only good for a boi anchor?
Since I have a lot of other projects, my budget is slim.
I don´t mind cast iron heads, since the weight is no problem. Too heavy a driver.
If this forum have info that can help, I´m most grateful.
Robert, Sweden
Old Aug 31, 2017 | 10:41 PM
Y2K's Avatar
Y2K
Well the heads are a weak point but so is the low compression motor that year. That said if it's a 2 barrel stock engine you should be able to shake a few ponies out of it with a set of headers a good intake and carb combo (not too big the heads and low comp. can't take a lot) and a mild cam.
Basically you need a package that lets it breathe better. Long tube headers, an Edlebrock performer intake and a 600-650cfm carb with a mild cam upgrade should get you there and maybe then some. Anything more than that will want more compression and better heads.
Old Sep 1, 2017 | 09:31 AM
Zspoiler's Avatar
I would start out with an Eldelbrock Performer. Then a set of headers.and dual exhaust. And a good tune up.Then decide on what you want to do with the car .Then save up your money and maybe get a crate engine.Since the amount of mileage that is on you original engine.
Attached Thumbnails Would new heads do?-130044932860518017_26257430996_o-1-.jpg
Old Nov 4, 2019 | 12:02 AM
kossuth's Avatar
Originally Posted by Trebor65
Hi!
Robert, Sweden
You need to know a few things before we recommend anything really.
1. Are you in an area that your car would be subject to smog inspections/compliance?
2. What kinda shape your existing mill is in?
If the car is subject to SMOG inspections what you can and can't do and can and can't purchase will be pretty important to know. Headers would have to be CARB approved with AIR tubes etc or stick with factory manifold etc etc. What I would do regardless is do a full leak down on every cylinder, basically determine what kinda health the current motor is in. If it's sick then throwing mods onto the existing mill will only hasten it's demise. If that's the case I would either start putting money away for a rebuild/swap/crate motor or turn that money towards other parts of the car.
If the motor is healthy a top end kit can really wake a motor up and cut a lot of unnecessary weight off the nose of the car. A decent top end kit would run you about $3,000ish. If you're considering a cam swap I would strongly consider hydraulic roller vs conventional hydraulic lifters.
Old Jul 11, 2020 | 03:18 PM
OP was a one poster and never came back. 3 year old thread.
Dustinho
Dec 11, 2009 07:58 PM
RcrX
Jan 25, 2008 10:49 PM
camarokid_80
Jun 5, 2007 05:00 PM
81CanuckZ
82-92 V8 Tech
16
Sep 25, 2006 05:32 PM
