TPI conversion questions
Old Feb 13, 2010 | 11:37 PM
80ZJoe's Avatar
July 2010 ROTM
Default TPI conversion questions
OK, so i just picked up a 350 TPI motor for real cheap, and i have a few questions in general and about converting it to carburated.
first off the casting #'s are 14093638 and the ID #'s are K1103FSG and i couldnt find much about it but it being a 350 from the yrs 86-94. any other info would help (hp/torque rating, 2 or 4 bolt etc.).
Now, is there any difference in this block than older 350's (like 69-80) besides the fuel pump? are all the parts still compatable? What all do i need to do to convert?
Can it bolt/work with a th400 tranny?
Can i just replace the TPI with a 4 barrel intake and carb and be good to go?
What type of electric fuel pump will be powerful enough to push it if converted?
any help would be appreciated
thanks
Old Feb 14, 2010 | 06:56 PM
80ZJoe's Avatar
July 2010 ROTM
also does anyone know if i can use a carbed (1980) 305 sbc distributor one the tpi engine when converted?
Old Feb 14, 2010 | 09:05 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
yes but be aware of what gear you need. you dont want the cam to tear up the distributor.
Old Feb 14, 2010 | 10:44 PM
80ZJoe's Avatar
July 2010 ROTM
How can i tell what gear i need?
Old Feb 15, 2010 | 09:04 AM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
you have to find out if its a roller cam engine. if so you need the melonized gear on the distributor or expect to be pulling it back out chewed up something fierce.
Old Feb 15, 2010 | 10:40 AM
80ZJoe's Avatar
July 2010 ROTM
how do i find out if it is roller or not? what do i take appart to look at? and what am i looking for?
And can i get those distributors with melonized gears from any parts store?
thanks
joe
Old Feb 15, 2010 | 05:56 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
it depends on exactly what year i believe 87 and up were roller cam engines. in which case you will eat a normal distributor gear. if you dont believe me i have pictures of what my 355 did to an 86 tpi distributor. i ended up getting a new distributor for an 88 vette which had the melonized gear already on it. theres also brass ones, carbon fiber, iron and a few more. so you need to figure out what you have so you know what you need.
Old Feb 16, 2010 | 10:27 PM
80ZJoe's Avatar
July 2010 ROTM
i beleive you,
i took some pics today, is this a roller? what distributor do i need?
Old Feb 16, 2010 | 11:26 PM
blarry450's Avatar
What's so great about a 350 TPI? Should I be looking for one too?
Old Feb 16, 2010 | 11:45 PM
80ZJoe's Avatar
July 2010 ROTM
nothing is great about them lol, i just picked it up cheap and thought it would be better than the stock 305 i was putting in my camaro, and now i want to convert it, so im trying to find out if someone can tell me if the above pic is a roller or flat tappet so i can figure out witch distributor to use.
