Starter Issues
Old Jul 2, 2011 | 02:00 PM
uestraven's Avatar
Default Starter Issues
Ive been trying to find a starter for my 79 camaro for months now. Ive gone through 3 different ones already and none seem to work. They always grind against the flexplate. I have tried shimming up to .120 and it still grinds. Could the flexplate be too big? is that possible? Please help
Old Jul 2, 2011 | 10:46 PM
spifff2003's Avatar
i would'nt think the flex plat is "too big" but it does sound as if it may be a different tooth count then the replacement starters you are getting.
Dave
Old Jul 2, 2011 | 11:40 PM
Only two flexplates, a 168 and a 153. If you didn't change the fleplate, then it can't be wrong if the old starter worked. Do you still have the old starter, or did it get traded in? I'd remove the solenoid and pull the plunger out to check clearance of the starter to the flexplate teeth with it bolted on. Then you can gewt a perfect look of clearance and know what shim is needed.
Old Aug 11, 2011 | 08:00 PM
FrankC's Avatar
I was having the same issues with my El camino every weekend was replacing starter or flex plate come to find out that my block where the started bolted up to had a hair line crack so every time we start the car it would grind and finally mess my flex plate. Check your block just to b sure i finally learned the hard way after 5-6 starters and a few flex plates.
refderek
Feb 7, 2014 10:10 AM
pcarollo
Sep 13, 2012 06:51 PM
Chaotic94
Jun 2, 2012 04:55 PM
DaTruth69
May 28, 2009 04:10 AM
ryan88z
Mar 9, 2009 02:43 PM
