questions about oil pressure
Old Jul 3, 2014 | 03:21 AM
jimm418's Avatar
Default questions about oil pressure
well i have a camaro with a 383 has high volume oil pump above 3k its pushing 70 psi idk if thats good or bad. idle is about 50 something
Old Jul 3, 2014 | 09:28 AM
Not a problem, and pretty normal for a high volume oil pump and good bearings. Might even expect a bit higher on a cold start up.
Old Jul 3, 2014 | 10:52 PM
jimm418's Avatar
60 on cold start
Old Jul 3, 2014 | 10:59 PM
jimm418's Avatar
when cold it goes above 80 when revving up to 5k
Old Jul 3, 2014 | 11:00 PM
jimm418's Avatar
almost 90 is that bad?
Old Jul 3, 2014 | 11:17 PM
what kind of oil? dont rev to much when engine is not at operating temp.
Old Jul 4, 2014 | 12:17 AM
jimm418's Avatar
15w-40 royal purple when warm its 40 something and it maxes out at 75 maybe but thats 5k
Old Jul 4, 2014 | 07:43 AM
Sounds pretty normal for a high volume pump and a tight engine to me. Would I like it a bit lower? Yes, but it's not seriously high, and I think your engine will be OK.
Old Jul 4, 2014 | 08:58 AM
when you change oil try 10-40
Old Jul 4, 2014 | 09:14 AM
jimm418's Avatar
im just gonna keep putting the same stuff in its been that way since new and i dont wanna change it. if u say its fine
