no spark from sparkplug/ carb isnt getting gas
Old Aug 21, 2010 | 07:13 PM
1976camaro's Avatar
Exclamation no spark from sparkplug/ carb isnt getting gas
so i was on my way to Wa on friday and my car died on the freway as i got into portland Oregon. no gas is going into hte carb but their is gas in the line where the filter is....also i changed my cap/rotor/modulator but no spark is going to the spark plug. is it possible that all the wires got fried from driving for 12hrs
Old Aug 21, 2010 | 07:23 PM
80ZJoe's Avatar
July 2010 ROTM
It is very possible to have a short in a wire, PO's can mess stuff up hardcore lol. Use a tester and keep following until you have some power. But what kind of fuel pump are you using? If its a manual pump it should pump gas if the motor turns over unless it's done.
Old Aug 21, 2010 | 07:35 PM
1976camaro's Avatar
what do u mean PO's never heard that before lol i used a tester and tested the battery/the cap and the wires that connect to the cap. their is power their but one i check the plug wires their is one i think the wires are bad but their fairly new.
Old Aug 21, 2010 | 09:08 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
PO = previous owner.
You may have fuel in the line but no pressure,so check the fuel pressure.
Why did you change the cap and rotor?
Your second post in this thread is confusing, what do you mean by the power at the wires connected to the cap?
How are you checking to see if there is power to the plugs?
Old Aug 22, 2010 | 05:08 PM
1976camaro's Avatar
I am the second owner my dad was the first
I changed them because I thought it was the cap and rotor
I used a meter to check if he cap Is getting power and it is but when the sparkplug wire is on their is no power reading on the meter
how will I be able to fix the carb problem cause I got gas in the line goin to the top of the carb where the fuel filter is but no gas is coming past that you think it's a cloged filer maybe dirt or something got in the line
Old Aug 22, 2010 | 05:47 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Yes, on older cars the fuel tank might have debris inside. This will lodge in the lines, usually the filter pickes those up. If the filter isnt changed or is very old it could fail, causing small partacles to get into the carb, this is unlikely, but it could happen, so most carb makers put a filter in there as well. Anyways, I dont think its come to that, sounds like, from your description, the filter to be the problem.
As far as the spark - this is interesting because what you are describing could be done a number of ways.... I am imagining you are putting the neg probe to a ground and the positive to one of the spark plug wire holes and cranking the engine to get power to it. I have never been acused of having a great imagination so I might be way off on how you are describing it.
So, lets assume that the plugs are fine for now and get to the fuel filter.
Old Aug 22, 2010 | 05:59 PM
1976camaro's Avatar
If it is the fuel filter that would explian the gas but what about the no spark
Old Aug 22, 2010 | 06:14 PM
1976camaro's Avatar
I also checked the plug wire with out the plug in it and that's where I have no power is it possible that all wires went bad
Soundwave
Mar 29, 2011 12:45 PM
Crunchy
Feb 6, 2008 08:24 PM
SHIVA178
Jan 15, 2008 08:28 AM
pyrofire127
82-92 V8 Tech
Dec 17, 2007 10:44 PM
pdpallen
Aug 28, 2006 05:17 PM
