ignition switch actuator?
Old Feb 12, 2010 | 07:32 PM
blarry450's Avatar
Default ignition switch actuator?
I somehow broke the ignition switch actuator on my 74. Any familiar with this type of scenario?
Old Feb 12, 2010 | 08:06 PM
I guess not, cause I don't even know what a ignition switch actuator is? Do you possibly mean the ignition switch tumbler?
Old Feb 12, 2010 | 09:11 PM
blarry450's Avatar
Don't think so. It's the metal piece which connects the ignition switch lock cylinder gear to the rod that pulls on the ignition switch
Old Feb 13, 2010 | 11:32 PM
blarry450's Avatar
The dealers only sell them for 76's bcuz that as far back as their parts system goes. Maybe I'll find the part # or maybe i can use the 76. In the mean time i'm applying an industrial JB Weld type of substance. Here goes nothing. Oh yeah, the dealer down here is showing only 3 left in the world for 76. Of course everything down here is all messed up since hurricane katrina....
Old Feb 15, 2010 | 12:58 PM
blarry450's Avatar
Correction. Its called a rack rod according to a chevy parts department employee. Its discontinued but should be the same in any chevy up to 78 w/o tilt steering. The search continues.....
Old Feb 15, 2010 | 01:35 PM
did u check ecklers?
Old Feb 16, 2010 | 11:16 PM
blarry450's Avatar
Checked Ecker's, nothing. I wonder if it'll be in a new steering column? I found a rack and gear combo in the help section @ car quest. Doesn't fit. Gonna modify it. Thanx for the suggestions. When you guys get a chance check out Glen's 74 Camaro on youtube. It's my inspiration.
Old Feb 16, 2010 | 11:23 PM
blarry450's Avatar
FYI; the piece is called an ingnition swich actuator only if you have a tilt steering wheel. If you don't, its a gear rack.
Old Feb 16, 2010 | 11:34 PM
check and see if u have any clasic car wrecking yards in your area. we used to have one that had only 10 yr old and older cars. when i had the 56 olds i used to go there alot. i havent been there in a while so i dont know if its changed, anyways its a thought.
Old Feb 17, 2010 | 02:27 AM
blarry450's Avatar
That's a great idea. Thanx.
JohnnyCars
Jul 23, 2014 01:27 PM
Delray Gugle
Apr 7, 2014 07:04 PM
tampatony
Feb 20, 2014 01:59 PM
evilmnky45
Jul 31, 2011 05:24 PM
w0211644
Mar 14, 2007 01:12 AM
