idle kick down
to any one that know about this problem, i have a 307 chevell engine in my 81 camaro the problem that i have is my idle kick down doesnt work to well. the car idles at starts out at 1000 rpm and then slowly climbs up to about 3500 rpm until i give the gas pedal a flick. the engine almost cuts out and then the rpms go down to about 700 rpm. what should i do
Ya it almost sounds like you have a stricking problem. I would go over everything including throttle linkage the valves and anything else you can think of. If it was me I might give all of them just a little bit of WD40, but just a little bit maybe like a drop or two, and see if that helps any
thanks for all the feed back, i lubed up the linkages with WD-40 and on the choke valve. it helpd a bit. i dont plan on keeping that engine in the car for long. im saving up to rebuild a small block 350, that i got out of my dads truck. its a new block that was put in his 78 chevy 3/4 ton truck. it only has 15,000km on it.
