Help wheel stuck!
Old Jul 21, 2012 | 09:29 PM
BasicConcepts's Avatar
Technical User
youd have to rewire the whole ignition system into switches for power... well you have an older car so maybe it wouldnt be too bad
Old Jul 22, 2012 | 01:46 AM
anthony7888's Avatar
Lol. I failed smog (because of timeing) on my 78 Camaro, the next day the arm on the window crank snapped of on my dads 69 pickup. Im borrowing my dads pickup, she will be parked until he gets the time and money to make her look good.
Old Jul 22, 2012 | 02:00 AM
Technical User
what!?!?!
Old Jul 22, 2012 | 09:17 AM
NavyK9's Avatar
Getting a new key did not work.
Old Jul 22, 2012 | 10:32 AM
Your ignition lock cylinder might need to be replaced. Could also be the switch itself is jammed, so you could disconnect it to test. There is a rod that connects the key tumbler to the switch, which is located on top of the steering column near the firewall. Or.....could be the shifter interlock is goofed up. In the engine compartment, look at the steering column. You should see an arm sticking out and has shifter linkage connected to it, unless its been removed. Pull up on that arm as far as you can. If the arm is dropped, the key won't turn. I'd actually check that first.
Old Jul 29, 2012 | 11:34 AM
NavyK9's Avatar
Even if it's a manual?
Old Jul 29, 2012 | 11:37 AM
NavyK9's Avatar
Nvm, found the arm its in up position with no play
Old Jul 29, 2012 | 12:13 PM
Yes, even if it's a manual. On the steering column, between the key and dash, is a collar about three inches long. That collar rotates when the shift linkage moves that arm in the engine compartment, and that's what interlocks your tumbler to both prevent the key from turning all the way on or off if it's in gear. Try grabbing that collar with both hands and make sure it's turned all the way counter-clockwise. Otherwise, I'd say you're going to need to replace the key tumbler.
Old Jul 29, 2012 | 12:15 PM
NavyK9's Avatar
Oh got ya.
Old Jul 29, 2012 | 12:36 PM
  #20
NavyK9's Avatar
Lol. I pulled my entire dash apart, and I tweak that collar to the left and oila.
