Help wheel stuck!
So I hop in my camaro day in and day out and start it up and it, sticks just barely as I start her up, a little tap and ignition pops back into place...
Today.... I put key in and go to turn and it feels tight and doesnt want to budge at all, I attempt to remove key, stuck, I tug a little harder....It pops out I shrug and put key back in and it slides in fine.. Steering wheel is locked in place and ignition WILL NOT budge... What in the heck do I do? Replace the cylinder? Is there a quicker fix? |
shake the wheel side to side when you turn the key
I did both sides, held it to each side, jiggled it to each side even had my buddy rock the car while I shook the wheel and tried to turn the ignition... Nadda.
hmmm, is your key really worn?
Yes, its fairly old.
Go get a new key made tommorow. I will punch my self in the gut if it was that simple. LOL.
could be. i had a car that was doing close to the same thing, used my other key (brand new) and it was good as new.
Will give it a try tommorow and update. Maybe my car is mad at me? The other day I was googling how to install a toggle switch and push button starter to avoid a key in the ignition. Maybe its mad for making threats against its originality.
lol a push button start still requires the key
Even with the toggle switch for standby? Hmmm Well guess thats what I get for taking everyones word for gospel.
