Engine will not start (sensors)
Old Mar 2, 2014 | 05:05 PM
Lee74's Avatar
Default Engine will not start (sensors)
I replaced the six cylinder engine in my 1974 Camaro with an earlier model V8 that doesn't have the sensors (Thermal Vac. Switch, Transmission Controlled Spark System, Vac. advance solenoid, TCS temp. switch, Idle stop solenoid) that were on the six. All of these sensors appear to get positive power from one tan wire that is powered when the key is turned on. I have removed all of the sensors and the tan wire is simply not hooked up to anything. The problem is, the replacement engine will not start and I am wondering if all of these sensors not being hooked up have something to do with it. The engine is getting fuel and spark, but it will not fire up. Any help would be appreciated. FYI, the replacement engine is a 1967 Pontiac 326. Thanks.
Old Apr 3, 2014 | 01:51 AM
greencamaro1981's Avatar
what is your timing at? and what carb setup are you running?
Old Apr 3, 2014 | 12:11 PM
No, those sensors not being hooked won't prevent the engine from starting. Was the 326 running when it came out of the Pontiac? Does it still have the points & condenser distributor? If so, the points may be out of adjustment, or it has a bad condenser.
Pontiac and Chevy have the same 1-8-4-3-6-5-7-2 firing order. HOWEVER, the distributor/rotor on the Pontiac engine rotates counter-clockwise, the Chevy rotates clockwise. If you hooked up the plug wires like it was a Chevy, that's your problem since the wires are installed backwards.
dmoneey05
Feb 26, 2012 11:03 AM
DCorey
Aug 8, 2010 12:32 PM
thetal1
Mar 3, 2010 04:29 PM
slvrblt2
Jan 20, 2010 09:35 PM
