Engine dipstick tube 350 removal help
Old Mar 19, 2011 | 02:04 PM
justinw23453's Avatar
Default Engine dipstick tube 350 removal help
I have a 79 camaro and i need to take the engine oil dipstick tube out. I cant find any bolts or anything to it. Someone know of where it is?
Old Mar 19, 2011 | 02:15 PM
there is usually a tab that is bolted to the motor. other than that you twist it and pull and the same time.
Old Mar 19, 2011 | 11:04 PM
You can't find any bolts holding it because there aren't any. The tube is just a press fit. You need to wiggle and pull up on the tube, but don't go animal and bend or snap it.
Old Apr 3, 2011 | 01:27 PM
tjay's Avatar
this tube traces directly into the oil sump. Go easy when removing it.
Old Apr 4, 2011 | 09:28 PM
walkingchaos's Avatar
what do you do if the tube just pulls out when you try and pull out the dipstick ?
Old Apr 4, 2011 | 09:29 PM
get a new tube.
Old Apr 4, 2011 | 09:41 PM
I still have the tube, are you saying a new one will fit in tighter ?
Old Apr 4, 2011 | 10:10 PM
A new one might, then again might not. Depends on if it's the hole in the block making it loose or not. Put the end of your tube in a vice and tighten it down ever so slightly to make it just barely out of round.
socalrs
May 20, 2011 08:19 PM
1995Camaro
Feb 4, 2010 05:01 PM
1998camarossclone
Jan 24, 2010 12:55 PM
cjoelmitchell
Aug 25, 2009 12:35 AM
jbe123
Sep 7, 2007 12:40 AM
