want overdrive not sure wich trans is best
If I had to do it again for the amount of money I spent (after I kept upgrading everything), I would be more inclined to consider Monster Transmissions. The local shop guy didn't have anything good to say about Monster however?
The 700R4 has a very strong first gear that will help you with your 60s if you are a track guy or help you run lower gears out back if you are building a DD for better street cruising.
74goatboy
11-10-2013 05:26 PM
