Rough Estimate for Synchro(s) Replacement?
Old Oct 2, 2022 | 09:30 AM
Jays74's Avatar
Default Rough Estimate for Synchro(s) Replacement?
Hi, wondering if a couple people could throw out a rough estimate on what a shop (in Kentucky) should charge to replace synchro(s) in a Saginaw? Should all be replaced at once while it’s torn down?
How equivalent is this all to a total rebuild? And if thats the case - is a Saginaw even worth a rebuild? 🤔
It is numbers matching.
Tyvm!
Jay
Old Oct 2, 2022 | 11:18 AM
I doubt you'll find a shop that will just do syncros,if it's coming apart it should get a proper rebuild with all new bearings and each gear at least inspected for wear and or replaced as needed.
Old Oct 2, 2022 | 11:27 AM
Originally Posted by Jays74
How equivalent is this all to a total rebuild? And if that's the case - is a Saginaw even worth a rebuild? 🤔
Tyvm!
Jay
If you plan on any real power I'd replace it with a Muncie or T-10 but keep it since it's numbers matching.
If the car is basically stock a rebuilt Saginaw would be fine and likely be a lot less money.
You're probably going to pay around $1000 for a rebuild,probably double that to get a Muncie.
Old Oct 2, 2022 | 06:55 PM
Jays74's Avatar
Thanks Y2K, this all makes sense and is very helpful- just the info I was looking for. I’ve read a bit about the weaknesses of a Saginaw with any kind of power in front. Moderate power is the plan, so I’ll talk to my local transmission shop about replacement options.
Old Oct 2, 2022 | 07:59 PM
Glad to help.
CowgirlupCA
Jun 25, 2016 12:27 PM
josh3408
Dec 13, 2010 08:26 PM
Lawhead09
Oct 26, 2009 08:50 AM
Gorn
Aug 11, 2009 07:59 PM
VanHalen
Feb 4, 2009 10:20 PM
