4 speed saginaw linkage
Old Mar 3, 2011 | 07:48 AM
mainejohn's Avatar
Default 4 speed saginaw linkage
I have a 1980 camaro, with a 4 speed sag in it. can i disconnect the reverse lock out linkage so i dont have to put in reverse to remove the key?
Old Mar 3, 2011 | 11:19 AM
Yes you can. Remove the linkage rod that's connected to the arm at the base of the steering column (inside the engine compartment). Then hold that arm in the "up" position with a wire to a screw or something else that's fixed to the firewall. Be sure to remove the other end of the linkage rod from the shift linkage so it doesn't get hung up.
Old Mar 3, 2011 | 12:22 PM
mainejohn's Avatar
okay good. thanks
greencamaro1981
70-81 Transmission & Differential
Mar 20, 2015 09:57 AM
mikes68
Oct 21, 2012 07:45 PM
Carkid70
May 8, 2011 08:14 PM
jwalsh66
Mar 5, 2009 07:53 PM
Edog
67-69 V8 Tech
12
Dec 26, 2008 08:44 PM
