air ride shocks in the rear
Old Mar 15, 2007 | 06:24 PM
74_camaro's Avatar
Default air ride shocks in the rear
ok right now i have air ride in the rear and they just come to one input so if i air one up they both work i was told by some people sometimes it helps to have them on seperate ones so u can load more weight to one side. is that true?
Old Mar 15, 2007 | 06:57 PM
TSTONE's Avatar
Default RE: air ride shocks in the rear
ORIGINAL: 74_camaro
I use to do that when I had my 72 formula - but that was to compensate for the fact that I had no trunk left.
Old Mar 15, 2007 | 07:02 PM
TSTONE's Avatar
ORIGINAL: 74_camaro
Old Mar 25, 2007 | 02:06 AM
1969 SS's Avatar
you should get rid of those shocks and put in a regular set.
your ride and handling quality will go up immeasurably without them. the reason most people put in air shocks is if they do a lot of hauling (which I doubt is your case), or if they are just trying to get their ride height back because they don't want to spend the money to fix an underlying problem the right way
Old Mar 26, 2007 | 04:35 PM
badinfluenceRS's Avatar
Get some Gas Shocks
the only good thing about air shocks is so you can Jack up the back end
jkeaton
Apr 9, 2013 08:00 PM
jason7504
Feb 19, 2010 01:38 PM
moparguy
Nov 25, 2008 03:41 PM
jenz
67-69 V8 Tech
Jul 15, 2008 03:23 AM
mikebrow74
Apr 22, 2008 11:30 PM
