Air Ride brackets from Ride Tech, wich size ???
Hy all,
i want to install the same Brackets like Ride Tech is offering:
CoolRide :: 1970-1981 Chevy Camaro, Firebird - CoolRide Front System - RideTech.com - Suspension Specialist - Online Store
To safe the cost of shipment to Germany, i will fabricate the brackets myself..
Therefore i just need to know the height of the upper brackets..i hope anybody is knowing that..
Thanks a lot
Achim
Thanks a lot
Achim
Hy all,
Thanks a lot
Achim
Thanks a lot
Achim
You may also find the spring pocket in the frame is tight on the bag and may have some interference. If it does then the spring pocket will need to be opened up also so it wont wear the bag out.
