2nd gen camaro question
I have a 1973 camaro, I bought recently - maybe a mistake - maybe not
anyways
I'm missing the front subframe
I've heard that if i purchase a later year like 1978 I just need to shorten the rear section and drill new holes for the rear body mounts and maybe a different bushing for the radiator support ( I have the original of this)
how correct is this ?
anyways
so was I but in investigating further I saw there are different frame schematics for 1970 -1973 than a 1976 and apparently a 1977 has different holes in the front for a difference in the bumper mounts
I did find a couple webpages that someone tried mounting a 1977 frame and it was not a direct fit,
so far from what I understand the 1975?-1981 frame is 3 inches longer and the mounts on the rear are moved back a couple inches also , I think that the 1977 frame would fit a 1973 but the frame needs shortened and or just new holes need drilled.
I also understand there are other differences in the lower control arms hole size and the spindles are different.
this is becoming a major bummer for me since the difference in a used front for a 1977 is much cheaper than a 1970-73
on a lighter note yes I found several 1975 + frames that were close ( less than an hour) and under the $300 mark but I'm going to drive 3 hours to get the one for a 1971 for $400 that I know fits. - unless someone else nearby has a 1970-73 frame etc.
current messes (as my wife would say )
1969 chevelle convertible ( frame up restoration 14 years ago) [needs new paint now]
1971 mg midget
1973 camaro lt - barn find - off road since 1980
1971 mg midget
Yeah that's why there are so many issues for front ends. If you look for aftermarket lowering springs, they don't have any listed for a 79. Same with aftermarket brakes. I had fused together enough parts from both years and I made things work. So, yes you can use different sub frames, but how much work do you have to put into it to make it fit? I would just go with something that would bolt right in. Trust me, pain in the A$$.
I've a 70 z28. The sub frame, I believe are the same to 73 and perhaps 74; however, the 70 upper and lower Suspension "A" arms are unique to the 70 and use larger ball joints from a 69 Chevelle. I would not be surprised if the Spindles and Suspension Arm mounting holes are different or of a different size. Only the 70 has the Rubber/Aluminum Bumper Stop mounted on the lower Suspension Arm.
When work on the front end of my 70, I usually end up finding the part that fits from a 69 Chevelle Parts Book rather then say a 71 Camaro Parts Book.
