So here it goes, my project thread (2nd gen)
#661
I was a little energetic last night. So I stayed late at work to see what I could come up with as far as a car part that I could make. I came up with a billet pistol grip shifter. Easy enough, right?
Remember I am not a machinist by trade. I can use precision measurement if I want to. I didn't feel like it this time. So I eyeballed everything except the slot in the bottom but even that wasn't measured for center. I just made sure the stick would be a tight fit.
I had my camera in my coat pocket so I snapped pics along the way.
The final shape. The reverse side has a relief for my thumb.
The finished product has a brushed finish. I kind of wish I left the mill marks in it. I like the raw look but the edges are way too sharp.
The stick isn't finalized yet. I will need to have the seats in the car along with the trans, console and everything. It will also be machined aluiminum. The holes are for counter sunk stainless screws.
#662
the new wheels and tires look great! what BS did you go with on the rear again?
I can't wait til i get my 17x11's with 315's on the rear. i'm thinking of going with 5.75" BS.
you can also rent the fender roller online. look on Craigslist locally too. i rented one locally to roll my fender lips.
#664
The wheels are 5.75" bs. Measure it up for sure Jason. I still think a 6" would be better after a mini tub. Actually after a tub job a 6.5" BS would be perfect without rolling the lip and still tucking them under.
As for the hood. I'm under no illusion the wipers will work. Most people with stock bushings are having problem. My front sheet metal is dropped 1/2" with PTFB bushings. I won't be happy until this thing sit on pavement and doesn't rub a bit.
#666
It's more like the subframe is raised 1/2", not the front sheetmetal dropped. The whole car is 1/2" lower in front wwith the thinner bushings.
I like the shifter, but I'd mill the finger grooves a lot deeper, just to look cool!
#668
