New Build Thread?
#303
While that cooks I'm starting on the engine. I don't expect any drama. Needs a cleanup and paint. I changed the cam without dropping the pan. It leaks a little. But it ran good and had good oil pressure. I'll check everything out while I can.
Nice and clean like I expected in side.
#305
Little bit o drama. When I pulled no 8 ex rocker, The spring clip that hold the lifter together was gone. I found it in the pan. 2 pieces but complete.
It seems as though it only holds the lifters together when there is no load.IE on the bench. I took a clip from an old lifter and put it in this one.
#306
wow nice find,i bet ur glad u found that before putting the engine in,never seen that happen before.maybe i better check mine,just kidding mines a solid roller,but i sure im gonna check all the roller bearings for excessive play,even though there practically new.
#308
Yeah I had no issues either. Only about 500 mi. on this cam and heads.
I did some measuring today. ,060 over nice and round. I'll get some plastiguage tomorrow and check the bottom. Everything is nice and clean almost no ridge at all.
Rering kits w/all bearings and gaskets are less than $100.00.
I cleaned and did some powdering.
black mtr mts.
the V covers were candy red over the orig alum. The alum was real splotchy and it showed. I'm doing chrome with ered over. I'll leave the ridges and the lettering chrome.
chrome on the intake.
black mtr mts.
#309
That's kinda what I did with my old Eddys too. Painted the ribbed area red, then wiped it off with reducer and polished the high edge:
