New Build Thread?
Old 11-05-2011 | 12:09 AM
If its the nose its urethane.
  #112
Old 11-05-2011 | 04:47 AM
rydeer's Avatar
Is urethane hard? I thought urethane was rubbery like the nose and bumper of an 80.I figure I can gouge the long crack and fill with epoxy, The spider I'm not sure if I should grind away or use a hole saw and just make anew with fiberglass.
  #113
Old 11-05-2011 | 10:25 AM
That's why I posted the link to the Vette forum. Urethane can be several types. Yes, the nose is urethane, but need to determine which kit is right for the urethane on a late 2nd gen nose.
  #114
Old 11-05-2011 | 01:38 PM
What year is your car again?
  #115
Old 11-05-2011 | 02:21 PM
rydeer's Avatar
my car is a 76. BB it was 5:45 am and I was off to a car show this morn. I havn't had a chance to follow the link yet. But thanks I will!
I be posting about the show,it was great!
  #116
Old 11-07-2011 | 10:26 AM
rydeer's Avatar
Got on the car. I rebuilt the inner fenders. I'm pretty concerned about the pass side. I was missing so much of the inner structure, I copied the drivers side but I need to refit the nose before I attach the inner to the outer.
Attached Thumbnails New Build Thread?-110.jpg   New Build Thread?-135.jpg   New Build Thread?-136.jpg
  #117
Old 11-07-2011 | 10:31 AM
rydeer's Avatar
I plan to reuse the cowl induction hood and air cleaner that I have. I'm going to attach the air horns on the air cleaner to the cold air in the front.I'm moving the blinkers behind the grill and plumbing the cold air from where the blinkers were. It is all in mock-up right now. I do have the ring that attaches the air cleaner to the hood.
Attached Thumbnails New Build Thread?-127.jpg   New Build Thread?-125.jpg   New Build Thread?-126.jpg   New Build Thread?-133.jpg   New Build Thread?-134.jpg
  #118
Old 11-07-2011 | 12:08 PM
Nice work on those fenders! Much better to save them, than to replace them anyway! The air cleaner idea is a good one too! Should perform better in hot weather, plus it will just be cool to see air intakes where the blinkers were!
  #119
Old 11-07-2011 | 01:01 PM
I had a ram air box on my Nova. It would lean out the faster I went. Just letting you know when you tune it. You start forcing air down its throat, your gonna eventually need more fuel.
  #120
Old 11-07-2011 | 01:10 PM
If he's got the cowl hood sealed to the air cleaner it wont force as much air. Some will escape out the cowl.
Quick Reply: New Build Thread?
